Scag Zero Turn Won't Start
Smoke
I have a zero turn 26 HP that will not start. I replaced the solenoid thinking that would fix it, but it didn't. Any suggestions?
Thanks!
engine model number info would be most helpful.
Sprinkler Buddy
Back when I had Scag's, I had one do that. It was the plug wire harness, the wire was broke where you push it down on the spark plug. I too changed the coil before we found the real problem. Might be! Good Luck, I know it's aggervating.
KennyV
Thanks!
First ... WELCOME to LMF...
Second.. ??? I'm curious, Why did you replace the "solenoid thinking that would fix it"...?
Unless you checked the solenoid, and had some reason to think that would fix it... I'm hoping you didn't just remove & replace it for no good reason??
Will not start is lacking in a bit of detail...
Are you meaning that it will not start, just spins & is not even trying to fire..., OR is the starter not even cranking the engine over???, I'm just needing a few more clues ... :smile:KennyV
Briana
Hey there! WELCOME to LawnMowerForum! :biggrin:
I moved your thread to the Scag Forum. You'll get a better response there. :thumbsup:
