Kohler Wheel Horse year unknown
misha84
I do not know much about this Kohler Wheel Horse. It does not have any information on it. I want to know if it runs diesel or gasoline. I swore that I smell natural gas from it. Either fuel must be very old enough to smell like natural gas.
Thank you
First it is a toro wheel horse with a 8hp kohlor gas engine.
Will say close to a 1964 like this one.
Does it run gas? I hope so because I never work on diesel tractors before. How do carburetor works with diesel fuel?
It has a K series Kohler in it. No it wouldn't run on diesel fuel. It sounds to me like you just have old fuel in it unless someone filled it tank with diesel fuel:confused2: Something just doesn't sound right here like you might want see how we react or you never worked on a tractor????? You had better do a little research on diesel engines on how they run.
It has a K series Kohler in it. No it wouldn't run on diesel fuel. It sounds to me like you just have old fuel in it unless someone filled it take with diesel fuel:confused2: Something just doesn't sound right here like you might want see how we react or you never worked on a tractor????? You had better do a little research on diesel engines on how they run.
Thank you.
