 - Nov 29, 2014
- Threads
 - 65
 - 24,995
Rodney,
Yes this engine has a pcv valve.
There is a quick & dirty test for excessive crankcase pressuer and this is to remove the oil filler when you turn the engine off.
If it send up smoke signals then you have excessive crank case pressure and excessive crank case pressure will send a lot of oil through the pcv vlave into the cylinder.
I have a color tune ( Gunsons product ) which is a spark plug with a window in it so I can see the color of the combustion.
If the motor is burning clean the flame is blue white , if the engine is burning rich it will burn yellow, if the engine is burning oil you get funny colours, greens reds & purples.
I double test this by flicking some oil into the carb while the engine is running and see what color that particular oil burns.
Just because you have 120 psi does not mean you do not have a leak into the crankcase.
