Howdy
I hardly ever post in any forum or FB in fact i don't even have account, Therefore was not sure what is the respond rate ,My bad ...:laughing:
The smart phone generation seem to have problems when they do not get an answer the instant they post.
Apparently according to the neice if the "like" comes more than a minute after she posts something that means the person actually hates her.
She sends me an email and expects answers instantly and when I dont she sends texts to 1/2 the extended family wondering why I don't like her.
Apparently this is fairly typical of generation I ( phone) and I might add she is 22.
Dosn't drive, thinks "poping around" is sending me a couple of selfies. can't afford to move out or even own a car but has no trouble finding $ 250/ month for phone bills.
There are some mower forums that seem to be frequented by similar persons, a dozen or more welcomes & howdys within a few minutes but no one actually addresses the problems.
And if you need to know I still use the Nokia 600 most of the time.
Now to work.
The clutch/brake pedal has adjustments on it and the brake itself has an djustment.
On the clutch you tighten the nut in the center to make the brake more agressive.
Follow the rod that pulls the brake on and you should find an adjustment .
Most times I am backing it off for customers to make the braking less violent.
The brake has to be set so that the belts starts to slip just before the brake comes on so the brake & the box are not fighting each other.
PS this is the 5 th time I have viewed your post.
There is a recient post function on this forum and a lot of regular users utilize this function so every time they log in they read all the new posts thus you get a large number of views bit a lot of them are from the same person or even the moderators.
