davbell22602
I have a kohler command pro vtwin 23hp on craftsman gt3000 50in. I'm thinking head gasket. Compression is 90 n 120psi. Replaced both plugs and coils have spark too.
Pull your valve covers off and make sure you don't have a bent push rod. That engine tens to have valve guide problems.
the cylinder with 90 has a serious problem and the one with 120 isn't much better. the good thing about the command twin is there is no compression release on that engine. According to Kohler the minimum compression on that engine is 160.
Oh. I read in kohler shop manual that it's not recommended doing a compression test and cylinder leakdown test was better.
