Jimmy Perry
5.0 hrs on my new SD. It has been flawless. Today when I engaged the blades at half throttle the engine choked down and stopped. I was able to engage at a slightly higher rpm and keep running. What is causing this? Bad Fuel?? This motor has always sputtered at little on initial startup when the choke is applied but cleans itself out rather quickly. Any harm to engaging at 3/4 throttle? Thanks for any help. - JP
