silver1
- Oct 4, 2012
- Threads
- 81
- 415
Discolored but as long as it isn't warped or leaking and has gas inside you are good to go and just use it.
I did.............
In my experience if a Briggs float is discolored that much it usually needs replacing. It can't hurt to replace it while you've got the carb apart. :thumbsup:
I have a float on order. I don't think it is the problem as I don't have good fuel flow. The fuel filter will not fill up! I have the tank with gas,
the shutoff "ON" and the fuel filter will not fill up! After some time(hours) it will have a small amount of gas in it. If I start it up with gas visible
in filter, it will start and run until it runs dry! (?) A minute or two. I will replace the fuel filter AGAIN and see what happens.
make sure something isn't blocking the fuel line between the carb and the tank. remove line from carb, and put below level of fuel in tank. Make sure the fuel runs with a full line diameter. If flow is slow or partial flow, you will need to clear the fuel line and fuel outlet on the tank I will sometimes put a blow gun in the end of the hose and then blow air back into the tank. And then see what comes out.
MY JD fired right up today. The fuel filter was half full and stayed that way.
I rode around for 15min. with no problem. Misses now and then, new plug maybe.
The RPM's are very high compared to what it was before the re-build!
I will hookup my Gage and see what it is.![]()
