Replacement engine for older Lazerz HP
Bicklebok
I would like to replace the engine in my older LazerZ Hp but Im having problems finding a replacement Kawasaki engine. It has an FH580V engine, and every site I visit says its out of stock. I would entertain a Kohler if I new exactly which engine would work with minimal modifications. The shaft size is 1" and 3 5/32.
Thanks!
Thanks!
Check out my post on Kawa builds - and ask the sales team.
http://www.lawnmowerforum.com/small...a-fr541v-top-end-bobbins-rocker-assembly.html
Trust that helps some.
KK
Sounds like I need to find a Kohler engine that will fit. Thanks for the tips
I am doing Honda, likely a rebuild - my way.
I am not saying do not buy Kawa, I am saying know what you buy.
With the trend being one that clings to a price point any engine
can be modded to set a new lower standard for a chainstore
market. It's how this whole debate around "residential" and
"commercial" got airtime. My view the difference is a marketing
thing aimed at sucking extra bucks from small business, essentially
the selfemployed unemployed. "Commercial" buyers are being
duped, IMO.
I digress....
KK
If anyone is interested, I just upgraded the engine on a 60" 1997 Lazer Z to 25HP Kohler. New motor drive Shaft is 1 and 1/8th inch and requires a new clutch and new clutch spacer. A little trimming required on the hydraulic drive end to accommodate the oil cooler, but other than changing the oil drain it was a straight forward engine swap. If you have an older 22HP engine, the new clutch is slightly larger and requires a longer deck drive belt, although it is possible to make the existing drive belt fit.
Ed
Thanks!
Easiest thing to do is to go to some where like Small Engine Warehouse , Small Engine Services , Repower etc.
These peple specialise in supplying replacement engines for old mowers.
Mower engines are fairly well standardised and come in 3 basic sizes ( metric ignored ) from push mower to 10' fairway mowers.
Nearly all engines from 8 Hp to 28 Hp have a 1" x 3 & 5/32 crank then they go up to 1& 1/8 Diameter.
So the criteria is how much fiddleing with electrial connections & throttle controls you are happy doing.
Usually the same brand engine will drop strait in & plug right up but you can replace your Kwaka with a B & S , Honda , Kohler , Tecumseh or any cheap Chineese copy you like just so long as it has a governor
Thanks bert! I just rebuilt the engine in mine for now and Im trying to get it running right. Im trying to find an aftermarket muffler for it now. That seems to be a challenge.
You most likely won't
In most cases the muffler is made specifically for the application so they end up being unique to that particular combination of engine & mower.
If you still have the old one, cut out the exhaust pipe ( note out not off ) then find a muffler that fits in the space & weld the old pipe onto it.
I have seen a lot of mowers fitted with a short universal motorcycle muffler for just this reason.
Might look real cool with an upright stack & top hat.
Thank you so much for the tip bert. I didnt think of the stack idea. I may do just that!!! Thanks again!
