Possible Challenge for all you mower gods.
CjSchan
I had this sitting in my garage when I bought the house. The gas tank was bone dry without the normal lacquer in the bottom like most old tanks. Dumped some fuel in and mowed the yard :thumbsup:. There was a learning curve to operating this self-propelled reel but it's cool that after so many years it still worked! I was wondering if you guys can tell me what it is, and maybe even what year it is.
Great find! It's a Craftsman 18" power reel mower, model #535 81980 :tongue:
Sorry I don't know the year but it was made by Murray for Sears. Believe it or not you can still get most parts for that Tecumseh engine from the Sears parts site. But I had a real hard time identifying the actual Tecumseh engine model. The Sears model number from the shroud appears to be 143-581052, but that does not cross-check to any Tecumseh model number. Here is a link to the Tecumseh 4-cycle technician handbook - see for yourself (the chart is at the end of the PDF). The Tecumseh model number may be on or near the flywheel?
http://www.smallenginesurplus.com/service-information/Tecumseh/tecumseh-L-head-w-sears-cross-reference.pdf
How does it cut? I had a very old manual reel mower that cut the grass like a dream as long as it wasn't too long.
My grandparents had a craftsman reel mower almost identical to that, except it was orange, and it was a briggs-powered 'eager 1'. That was the only mower they had. Became mine after grandpa passed away. The grass catcher is awesome! I've never seen one with a grass catcher!
Judging by the script on the ID tag.....and the crass catcher....I'd say it's the same vintage as my craftsman tractor, maybe a little older......but, I have no Idea how old my tractor is....:laughing:
Probably from the late 60's - early 70's.
Mystreba, that's how mine was, too.....those reels hated long grass. Eventually, the self-propelled unit messed up, so I took off the engine, and tossed the rest.
BTW, GREAT pics!!!!
I just realized you addressed the"mower gods"....i misposted. HEY CAJUN!!!KENNY!!! Question for you here! :biggrin:
Sent from my WX445 using LMF
Ha ha hahhhhaaaa...
Actually you generally catch almost all the cool older mower questions... thats great being as you seem to have owned a lot of great mowers... in some way or another....
I never had one of those, Ive seen them... & dreamed of having an engine on a reel when I was a kid pushing around a reel back in the 50's.... :smile:KennyV
Seeing that mower reminds me of one that my Grandfather had and passed down to Dad. It was a self propelled Reel, but the start mechanism was a crank handle that wound a coil spring and a lever released the spring to start the engine (instead of a pull rope). I may have posted about this quite a while ago, but I couldn't find it.
Does anybody else remember the crank start ?:thumbsup:
Sure do... More like a wind-up start ... I did NOT like them, I always could pull an engine over faster than that spring ... and it seemed like a gimmicky way to start an engine...(sorta' worked) but took a lot of time if it didn't start on the 2nd or 3rd try... you could have been started & long gone with a simple recoil starter... :smile:KennyV
The advantage was that Gram (my Grandmother) was all of 90 Lbs. and she could crank it (wind it up), but couldn't pull one. :biggrin:
Had not given that a consideration... I can see that would have been a good motivation to make a better starter method:thumbsup:..
I don't know if it was the weak wind up spring or the need to repeat the wind up several times to finally succeed in a start... but that design didn't stay around very long... :smile:KennyV
