FarmGeezer
I'll take that advise to heart and re torque the gaskets. Thanks for your help.
Regards,
FarmGeezer
Regards,
FarmGeezer
The very first thing is we need the make and model of the engine you are working on. This is the reason no one give you any specs. I am going to take a guess here and say you have metric bolts??? To get a torque specs we will need the proper bolt size not the wrench size. If you have 5/8 fine thread bolts holding that head down its something I have never come across in my years in the trade and you would be looking at 150 ft. lbs. or better. By any chance do you have a 20HP Briggs and Stratton in this mower? Toque bolts in two increments, first 200 in. lbs. and then 370 in lbs. This is just guessing as to what you have.
Not meaning to nit pick but the 150 ft lbs is of course 150 inch pounds which should be obvious from the latter two figures which are both inch pounds
I have no idea what you are talking about here. I got my information off a torque chart. A 5/8 bolt is what I would call a large bolt for a lawn mower engine head bolt. They would use something like that on a large diesel engine head bolt. For a standard steel coarse thread 5/8-11 bolt grade 5 bolt my chart calls for 154 foot pounds of torque not inch pounds but if you need it in inch pounds that will come to 1,848 inch pounds.
