sheetmetalbabe
- Apr 24, 2015
- Threads
- 6
- 45
OMG
I took the shroud off and there wasn't anything under there except a little film of dirt, but I cleaned if off.
I put B&S oil in it. Called the John Deere Dealer and he said I shouldn't mix the part synthetic oil with the regular and it would get hotter but not enough to make it die.
I mowed 4 laps!! And then it died. I cooled it off with my leaf bower and mowed 2 more laps. Before it dies it starts surging A LOT.
I also noticed the air plenum extension was coming apart and the clip was barely on there. If you close the hood and look thru the louvers there are some gaps where the
extension fits around the grill on top of the fly wheel. Sounds stupid but if all the heat isn't exiting thru the louvers could that make it too hot? The air plenum extension has a small melted spot on it.
I took it off and tried to close the gap but it didn't work. JD dealer is closed and they don't have any in stock anyway. I can't find any pictures of one but I think the gap should be closed????
I did forget to loosen the gas cap, I will try to remember when I go back out, but I did blow air thru it yesterday and it is clean as a whistle.
The JD guy said maybe a coil???? Guess I will watch some youtube videos on coils and check back to see if anyone has any ideas.
Thanks for all the tips, I do appreciate you all taking the time to read this and reply!!!!!!!
