John Deere L120 over heating?
Also when I took the old fuel pump off there was no gas in the line from the pump to the carb.
before the new pump the fuel filter was all the way full of gas, now it is about half full of gas like it used to be.
motoman
Glad to see responses to this thread. I respect the packaging engineers with their fan flow (cfm) and shrouding design. I have also wondered about the hood. On my dyt 4000 there is a boxed shroud on the hood that mates with the fan intake. When I put on the oil cooler I carefully preserved it, but put two big hole in the sides of the hood for oil cooler fan intake and exhaust. It would be good for someone to tell us what that shroud on the underside of the hood is expected to do. It does not provide cooler air. So perhaps a guard against debris and grass which cold block the engine fan intake mesh??? IMO the weak link in these ac engines is the head which can easily overheat. Next, measured oil temp in the sump of 280F-300F (or more? ) not conducive to rod bearing and main life. Plus (still a study in process) the head may benefit from a cooler block through conduction.
Once more for new readers...the coils contain transistors (think speaker amplifiers) which only tolerate so much heat. So an overheated engine can affect several areas.
edit: I now see in the previous responses that the shroud (plenum) may be to direct cooler air into the fan. Sorry I missed that response. Still, on my Intek is feels like it merely traps more hot air for circulation.
shiftsuper175607
So you saying we don't need to operate the way they were designed to operate.
If it's that way the next time you need to change oil but all you have handy is automatic transmission fluid just put that in and it'll be ok.
Hoods and oil changes are not even apples to oranges.
Come on...Zero turns don't have covered engines.
What is your problem?
