Ten to one says you have a blown head gasket.  Pull the head and take a look.  Will be blown between the cylinder wall and the push rod cavity.
Well, that didn't go quite as I had expected!
I have replaced the head gasket, now with every thing back in place, the leak down tests look much better, no more noise through the body of the engine via the oil filler port.
I started the engine and it run great. I took it a short distance and turned it off to wash everything down. Now it won't start up again. let it sit for a couple of hours and tried it again, it ran ok for 10 second, then started popping badly and stopped. Put it in the garage to sit over the weekend and tried it again Monday morning, still just pops and sputters and backfires into the carburetor, but will not start.
Thinking the timing was out, I checked the flywheel key. It is not a problem, solid and not partially sheared. Then I turned to the electronics. I went through every lead on every switch including the key switch and seat switch. All were good, no opens nor grounds (except were they should be). Tried to create a problem through each contact of each switch(Isolating only one at a time) with pushing, pulling and applying pressure, but could find no troubles.
 I disconnected the kill wire to the engine, (thanks for the tip Bert), and run a by pass jumper to the fuel solenoid, Still the same occasional back fire, but not even close to starting.
Pulled the new spark plug, it is black with soot again after only 20-30 seconds of running. preformed the leak down test again. Have good result with only about 20% loss on the top dead center position.
This engine must have a compression release on the intake valve during the compression stroke since the leak down doesn't show good results until the last 60 degrees of the 180 degrees of the compression stroke. then it looks great for the last 60 degrees of the stroke and the next 170 out of the 180 degree of the power stroke befor the exhaust starts to open.
I'm not sure what to do next, the valves seem to be sealing OK, the head is no longer leaking, but their is soot on the plug after just a very short run time.
any help would greatly be appreciated.
thanks Rex
