mr.farmall
 - Mar 13, 2014
 - 12
 - 65
Check for air leaks,
Spray some ing like WD 40 FROM A TRIGGER PACK ) all around the carb to engine area.
If it makes a difference then you have an air leak.
Thanks Bert for the suggestion on the air leak.
I started to look at it tonight with intentions to do your spray test, then got the thought that I should just check the fuel pump, since it was one of the few things I haven't checked. With the fuel line off in a can, It seemed to work as it should. I put it back together to start the spray test, but the engine started and ran perfectly; no hesitation in starting and no backfiring. it ran constant and the governor wasn't working back and forth to keep it running. It was smooth at all speeds.
I didn't get to your test, but I'm not very satisfied that it just started working. I don't like unanswered results. So my question to both you and ILLengine or anyone else that might be following this post, is; could just the fuel pump have caused a lot of the backfiring that was previously happening? Could just having the pump run 1/2 cup of fuel into a can, could this have corrected the problem? Do these air operated fuel pumps have a track record of problems? and should I just try changing it out. (I really don't like to just change things out without a reason).
Thanks again sooooo much for your assistance. I feel blessed to have had your help.
I'll put it through a good run tomorrow and see if the trouble is really gone!
Thanks Rex
