Murry Furry
I started this project in mid January.
Febuary tenth i got a ignition and a solinoid. At this point i still though it was going to have a electric start.
On the thirteenth i found a starter for fifty dollars.
On the fifteenth i got the money together to buy it.When i went to get it, my buddy couldn't find it. So he sold me a manual recoil for ten bucks. The next day after school i put it on.
On the twenty-fourth of Feb i was tightening the shroud, and freeing up the motor. i gave it a good pull to see what i could do, and the remaining fuel in the bowl got sucked in, and the thing gave a weak pop. i still don't know how it works, i just know it dose. there are no wires hooked up to any type of ignition. it just has its internal wirering.
On the twenty-fifth i got the motor started, and run. i didn't have a fuel line. i just primed the motor and pulled to start it. i started it three times, and then went home to do more planning.
Yesterday i rigged the tank in place and ran a make shift gas line. then i started it, and ran the motor for a good ten minutes.
