Welcome to the Hustler Forum -- Check in Here First!
jdevr1
Thanks-have had a Hustler Raptor 1yr.
Ltmt
  • / Welcome to the Hustler Forum -- Check in Here First!
Thanks have a 07 Fastrak 42 with 17hp Kohler. Recently it has started dying on me after a few minutes running. It will not start again and I notice there is no gas in the filter. I believe it is sucking air through one of the fuel lines. Need help on parts i will need to go from inside the fuel tanks to the carb. Especially around the tanks. Any help is appreciated.
Nutcase2be
Hello All,
New here, but have looked on the forum for help in the past. I'm the proud owner of a new bouncing Raptor SD 54. Waiting for the grass to grow enough to mow here it Ohio, can't hardly wait. :smile:
Hustler Ed
Hey folks.
Purchased a Raptor SD 54" about 3 weeks ago. My first ZTM. Think I'm going like it. Have about 2 ac yard.
Kremeneon
Hey folks.
Love mine, practice your Y turns. The wide tires make quite good divots if you let one stop.
Hustlahh
New Hustler Raptor SD 60" checking in. My property is 5.6 acres total with a 1/3 or 1/2 of that being a pasture. After visiting a dealer I ended up buying from Lowes to get 10% off and 18mo special (0%) financing. I hope I never need to use the factory warranty and if I do I hope I don't have issues at the dealer. I expect to pick it up at the end of this month and I refuse to mow until then. :cool: I'll update later with a picture. I already bought the mulching kit for it and while at the dealer I picked up a set of blades, oil, and filter. I'm holding off on the flex forks until I log some hours.
JohnCardin
You may not want to hit the really tall stuff with the mulching kit right out of the box. That's gonna be ALOT of grass that you're gonna try to chew up in the deck and it may slow you way down.
Hustlahh
Thanks for the tip. I won't use the mulch kit until leaf season. I'll baby it for a bit and break it in easily. I suspect the grass will be pretty long by the time I get the mower so I'll start it off with the highest setting. Can't wait!
Ron Harper
Have Hustler Raptor sad that I just bought. Thanks for the add to forum!
Thanks for add
If you're new to the forum, please reply to this thread and introduce yourself and your mower (that is, if your mower have a name). Maybe attach a photo or two of your mower and show off your pride and joy.
Also, if you haven't done so already, you can upload a user avatar (picture under your user name). You can do so by clicking on settings and "edit avatar" or just click here.
Please be helpful and friendly to all other Hustler owners (how could you not, right?) and if you like this forum, tell your friends about it.
We want to make this the best resource for Hustler mower owners, and to do that we need your help! Questions? Experiences? Stories? Data? Photos? Articles? Links? Cool Hustler stuff? Post it here!
Last but not least, please let me know if you have any suggestions for the site. We'd love to hear them.[/QUOTE]
hollywood165
New owner of a Raptor SD 48 inch.
