Tiger Cat First Blade Removal
rfc
Well I made it harder than it had to be. Used a 6" c clamp for the side blades and a breaker bar. Then the fun began with that middle blade. The pulley turns with the nut and I couldn't get it blocked correctly. So, I borrow a 3/8 drive impact wrench and it wouldn't budge. Then went to a 1/2 heavy duty and the nut zipped right off :laughing: Anyway my question is what impact to buy, 3/8 or 1/2, brand, Craftsman ok or chitty like most of their tools. Is 75 ft lbs the correct torque ? Thanks in advance.
reynoldston
Myself if I only had one impact it would be a 1/2in. The 3/8 is nice for light duty engine work. I find I don't use my 3/8 impact very much. If you do buy a impact wrench just make sure you buy the impact sockets to go along with it. Just a cheap set of impact sockets from HF will last a long time.
kwak
Yes 75ft/lbs is what the owners manual recommends for your blades.
SeniorCitizen
Build a blade blocker that will work on all three blades. Lay it on a blade open side down and it stays there. A clamp is a pain in the ****.
If you are going to buy an impact wrench then get a good one.
I think the one I use is an Remington has 3 times the impact energy and usus 1/2 the air of my previous ( now back up ) one which came in the air kit I got with the first compressor.
Just watch the length of the shaft a lot of the better ones have long shafts which makes getting under decks a bit difficult.
tigercat
I made a heavy gauge sheetmetal tool to be a third hand and hold the 1/2 drive socket & breaker bar underneth the deck as I loosen the top nut. I also use the blade buddy to lock up the blade from turning.
I have a 1/2 drive impact gun as my back up but I never needed it so far. When I remount the blade I torque them to 75 LBS.
reynoldston
Looks like a good idea. I think I will be making one this coming spring. How did you fasten the sides on glue?
jekjr
We normally change blades daily on my Tiger Cat. We use a Craftsman 1/2" 19 volt cordless impact. It works great. We pull the mower up on a sidewalk or driveway and stick a small floor jack under the deck in the very front and raise the mower that way.
A couple of times we have had a blade that the impact would not break loose. What we did in that case was wedge the bottom bolt with a combination wrench and then tool a long breaker bar in top and take it loose.
If it is possible we always try to change the blades early in the AM when everything is cold.
clay45
If I understand you correctly you slide that jewel on the end of the blade with the ears hanging down? I tried wedging a short section of 2x4 to no avail and finally acquired a longer breakover bar that would hit on the rear wheels. Your hootus looks a whole lot handier and works on the center blade. I'm just too stupid to see how it works.
Please explain it to me.
