Howdy - I have a 1997 craftsman tractor with a 24hp kohler engine and hydro transmission - model #917.258910. The engine started shuddering when I put it drive (but reverse is ok), then it shredded the ground drive belt - which was very old.
I put on a new belt, after a half hour the tractor stopped, the engine stalled and the belt ended up in between the transaxle pulley and the transmission.
After this I noticed that the belt keeper above the transaxle pulley was missing, so I made a new one and installed it. Same think happen, only this time enough of the home-made belt-keeper was left that I could tell then the pulley had sheared it off - I can see 2 pulley tracks in the keeper. Belt also jumped off after a few minutes.
I'm sure that I'm threading the belt correctly, but I noticed that the pulley with the fan is not in the same vertical plane as the transaxle pulley, so I'm thinking that they're not aligned. The fan pulley does point directly to the transaxle pulley, but it comes to it at an angle.
I can't find anything about the correct alignment of the pulleys, and I'm afraid if I try to bend the fan pulley assembly so it's in line with the transaxle pulley I'll put it out of alignment with the engine idler pulley.
If anyone has a picture or diagram of the correct alignment I'd be much obliged.
I live in New Hampshire, use the tractor as my snowblower, and will be up to my eyeballs in snow soon if i don't get it fixed.
Thanks -
Thanks -
