mowerman05
My great dane is about 10 years old, has a grease fitting under the deck in the spindle housing on the back side. have only changed one complete spindle assembly in all the years I have owned it.
I don't like this,just how often to replace bearings then?
Never seen or heard of one till I bought this run.If the bearing had to be replaced on the Great Dane annually it's no wonder they went out of business and were discontinued.
When I worked in manufacturing when we would service some machinery that run 24/7 we would replace all bearings once a year. So if it is a problem in your heart I would sat once a year then you should be safe. As for myself I wouldn't change them till they got noisy, but that's just me.
As such the very first thing I did ( as with any impliment I have not seen before ) was to download the factory service manual and parts books.
When you don't know any better , following the written instruction can't do too much damage.
Oddly enough I have found quite a few "rebuilt" machines of different breeds where the shop has made a total mess of the job with wrong sized pulleys, tension springs working backwards or not fitted at all etc, etc.
And here is the relevant page for any who might be inclined to believe this white man speek with forked tongue.
By virtue of the fact the annual service is listed after the 500 hrs service one presumes GD intended these machines to be substantially more than 500 hrs/yr
I don't doubt what you were saying about the GD. I think probably that was the reason for there downfall and being discontinued, they didn't do well. There was just to much down time and maintenance or up keep involved to make the mower profitable.
