exotion
Look at the muffler. If it has a 12mm nut with a hole for the exhaust to escape, remove the nut. Attached inside the nut is a screen which gets clogged from time to time from using outdated (paraffin based) 2-cycle oil. Either clean the screen or pinch it off with a pliers and discard. Reinstall nut and enjoy your blower. And only use Stihl ultra synthetic oil to prevent future problems.
That was removed ages ago and unless you wanna buy that oil for me ill stick to echo thanks
