I go thru the normal starring procedure.
3-6 primer pumps
Full choke and pull til pops
Turn off choke
Full throttle pull starts by 2-3 pull
As long as it has been used in last few days it's no problem starting. Sitting a week or two then gets a little stubborn.
We usually start and run everything at the shop before heading out to avoid problems in the field.
