Oil leak at crank case
psdguy95
Hello. I have a toro super recycler model number 20465 ( 1997 model ) and it has developed a bad oil leak at the crank case seal. I'm mechanically inclined so fixing it is not a problem. The only problem i have is i've never torn into one of these mowers before and i can't find any service manuals for it. Has anyone ever had this issue before or know where i can find a service repair manual for it?
Thanks for the input everyone. Is it really as easy as removing the engine and separating the two and replacing the seal?
or hit it with a big club....
I guess I don't understand what hitting it with a big club will do other then breaking something, use a BFH and you can do more damage????? :confused2: If its the seal I am thinking about it should be replaceable without pulling the engine but might easier by doing so. OR JUST HIT IT WITH A BIG CLUB????
