dewguy1999
- Aug 14, 2014
- 145
New member here. I have a Lawn-Boy 21" SilverPro Series Mower, 6.5 HP DuraForce engine (2-cycle), model number is 10247, purchased new in September 2000. In 2007 I was having starting problems and with the help of another forum I received advice and replaced the CDI. Well, after approximately 7-years it's having problems starting once again and I think it might need another CDI, but this time there may be other problems as well.
The last few years it seems to be smoking more at start up than usual as well as occasionally spitting something from the muffler (which I now believe to be fuel mix) but one/both symptoms stop once the engine warms up. I'm not positive but fuel may be going missing which I suppose my be due to the above. Tuesday I went out to clean the air filter which I haven't done in a number of years and realized that not only was there a patch of oily dirty stuff in front of the muffler, but the air cleaner housing, most of the engine from the cowling down as well as a good portion of the deck around the engine was also covered in this dirty stuff. I got most of it cleaned off, accessed the air cleaner filter, (which was amazingly cleaner than I expected considering everything on the outside) cleaned it, oiled it an replaced it. Some of this mess may have been my doing as I have overfilled the fuel tank a few times, but I think there may be something else wrong.
Yesterday, I went out to see if I could get it started and mow the lawn without any success. Due to it's inconsistent previous behavior I tried starting it without priming it, wouldn't start, tried priming it (3 presses) wouldn't start, tried priming it (3 presses) again with the same result of no start. Removed the plug and cleaned it, put it back and tried again still nothing. I did not check for spark yesterday, but it was producing a spark a few weeks ago when I checked it.
I don't really have any experience with internal combustion engines (2-cycle or otherwise) so I'm really in the dark as to what may be wrong. From what I've read on the net it sounds like it may be the carburetor or shaft seals (?) causing the fuel mess. Could this fuel leak (?) cause the starting problem or would it only be caused by the CDI failing? Is the OEM replacement CDI still the only choice or are there good 3rd party alternatives now?
Back in 2007 when I replaced the CDI it didn't have any other problems and the new CDI made sense but now I'm not sure it does. I'm now wondering if it makes sense to put on a new CDI or replace other engine parts on a 14-year-old mower (2000)?
Thanks.
Thanks.
