Good n Dusty
- Jun 26, 2014
- 20
Finally back! I picked up the head gasket this morning and put it in and adjusted the valves and put it back together and still will not start. I tried everything I could think of to get it to run and there is not a pop or a kick or anything. I checked the compression and have about 140lbs. The fire is good and bright. New plug or old one. I even put a little gas in the intake and still nothing. I checked the valve lifter clearance again and tried again. I did notice a couple of things as I was trouble shooting. One is that there is a little blow back through the intake. The second is when I rotate the engine I notice that the valve lifter actually goes down a tiny bit (opens the valve) on the up stroke and then closes the valve all the way. This is about 3/4 way up to fire. Any hope for it?
