Good n Dusty
Hmmm! Interesting debate there guys. Lots of input that led me to take the head off the motor and see what was up inside. I had the carb and fuel shutoff solenoid off and cleaned. The solenoid seemed to be stuck partly open. It moved up and down with little effort and I tried on a 12v battery and it worked. I installed and it worked with the switch. I mean I could hear it clicking when I turned the switch to on and off. I assume it is working now. I have taken the head off and there appears to be two channels in the gasket on the narrow strip between the piston and the push rod cavity. This must be where the oil is coming from. The sleeve is in excellent condition with no scratches or signs of wear from the piston rings. Should I assume for now that the rings are OK and just replace the head gasket? What about the valves and seals. Should I take the valves out and clean them while I have the head off? Thanks for your help.
