djdicetn
- Sep 3, 2012
- 2,193
I understand that you were quoting from the gravely manual, I would just like to know what the "certain conditions" are. It would be great if you could find that out! I wouldnt mind betting it has something to do with mulching but thats only a guess. If mower manufacturers really wanted us to heel the deck, they would come like that from the factory!
Heeling the deck may add more to the striping look but as I said, the stripe should be secondary to the cut. I also understand that the grass will, or at least some of it be cut twice. ie, front and back but, what happens between the blades. I would hazard a guess and say you'll increase the risk of a tear rather than a cut, deck build up, choking, clumping etc.
But think about it, if grass is getting cut at the back of the deck, where do those clippings go? They will circulate around each chamber, get sent from the discharge side to the trim side. It already happens with a normal deck setting but if lower in back, its going to add to it. Clippings will be chopped up more which can be a good thing but if there is moisture, you will most likely get a mash and more deck build up which create more problems.
There are thousands upon thousands of lawn cutters out there. I'd bet the amount of guys that heel the deck would be barely registrable as a percentage.
As far as needing a commercial deck to create stripes, or get better ones, thats not necessarily true. Ive seen stripes from JD lawn tractors that are up there with the best of them!
To heel a deck just for a little more stripe seems well, crazy to me! Stick a roller or rubber flap on the back of the deck if its important to you! Remember, some grass types just stripe better also, even some commercial decks stripe better than others.
I went searching on the subject on this forum and came across this
Seems to me you were perfectly happy with the way it cut, or should of been! I cant figure out if you tried with the "heeled" setting or not so, did you? And is what you wrote here what happened? If so, its basically describing what I would expect!
From my research on here, seems you bring up "heeling" quite often. Have you actually done it yourself yet?
That's a very old post by me when I was researching and at that point no...I had not tried it yet(I was just "speculating" on the possibility of buildup). Since then I have added a Gravely OEM mulch kit.....AND....heeled my deck and I am VERY happy with the resulting cut quality improvement(and the complete disappearance of grass clippings:0).
Actually, when I first got my Gravely there was absolutely no grass clipping buildup underneath the deck(just like I stated). After mowing with it more, it began collecting clippings underneath the deck(especially in the "corners" and "flat edges" of the deck) requiring me to clean it after mowing. The brand new paint surface probably prevented it from collecting early on. After adding the mulch kit and heeling the deck the grass buildup was reduced by half and it only takes me about 5 minutes with a putty knife to clean after each mowing. I think part of the reason it reduced the buildup is that the Gravely mulch kit completely encloses each individual blade in a circular vacuum baffle. With nothing but rounded edges surrounding the blades there's really nowhere for the grass clippings to collect. Plus the mulch blade design inside the vacuum baffles force most of the clippings down and into the cut grass.
I can wholeheartedly recommend a mulch kit, along with heeling the deck, and there should not be any problem with buildup like you thought.
