Need help replacing handle on HRX217HXA
shacky
ordered new handle for my HRX. The studs had broken off on bottom end. I tried to swap the controls over without disassembling but the control piece fell apart on me. Now I have to figure out how it all goes back together and will need schematics to figure it out - or detailed pictures like I should have taken in the first place. But even that may not be enough to show the spacers and all.
I just got it running perfect with all your help here - new carb and all carb gaskets. Now I'm stuck with the handle repair.
shacky
Hey Mark. Whatever you tried to post came up as error.
mechanic mark
Click on error, should be illustrated parts breakdown for your handle assembly HRX217HXA, use zoom in feature.
shacky
Duh!
Thank you so much!!!
shacky
Need help figuring out how to install silver spring inside speed handle. I have it in place in picture but it's not doing anything. I can't figure out what the spring ends should be hitting.
shacky
Another pic
robert@honda
Here's a pic of another HRX that should help; the spring appears to be reversed in your image. This photo was made with both drive and blade levers held all the way forward for clarity:
shacky
Thank you Robert!
shacky
All buttoned up and running like new! I could not have done this without Robert and Mark. Here are a few pics:
