Need help replacing handle on HRX217HXA
For anyone else trying this. Make sure you connect this big spring before putting the speed handle on the stud. I tried to connect the spring after and stabbed myself in hand with needle nose pliers. Then I realize you need to disconnect the handle and cable in order to put spring on and then slide the handle over stud. Once you figure it out it's relatively easy.
