Ric
Less time before I have to replace.
Well that may be but when you take into consideration the cost difference in the tires plus the weight difference and what it's going to cost to use them you'll be throwing money away.
Well that may be but when you take into consideration the costt difference in the tires plus the weight difference and what it's going to cost to use them you'll be throwing money away.
You can however go to a radial instead of a biased ply tire, that will help the tire life. Our tandem trailers were chewing through the rear tires when they were bias. Now we run radial and we get two seasons out of them vs. one with the bias.You should replace your tires with the same size and load range tire that's on it when it was purchased new. Your trailer just like your truck is set up for the GVWR.
Okglad someone told me I was actually just looking into tires but I will wait I definitely need a spare tho
Wow I would never drive on that![]()
