I don't know the story on the engine. I bought the mower used a few weeks back. Not positive on the Toro number but I think it'sWhat is the whole story on this engine? Does this carb have a choke? Is this a different carb from the original? What is the Toro model number?
Hard to say what's been done with a mower somebody else owned. It has a throttle, governor, and a primer bulb.Well it either primed by hand, has a manual choke or auto choke. If someone replaced the air cover with something they had on hand it probably doesn't have a primer bulb. Does it have a throttle control or govenor I'm wondering if someone replaced the carb at somepoint and got the wrong one. The prime hole is very obvious and should not be plugged
That part is NLA and with that hole plugged it's isn't going to prime anyway.those darn filter housings will warp and also where it mates to the gasket will flatten out and it wont prime .....make sure its in good shape and replace it if need be good luck
Ok... two questions.That carb hasn't got a primer bulb, its fitted with a choke control. and the part number for carb is 498965
Sure looks like a primer bulb to me.Well a pic is worth a 1,000 words, eh?
