What is the whole story on this engine? Does this carb have a choke? Is this a different carb from the original? What is the Toro model number?
I don't know the story on the engine. I bought the mower used a few weeks back. Not positive on the Toro number but I think it's
20487
Well it either primed by hand, has a manual choke or auto choke. If someone replaced the air cover with something they had on hand it probably doesn't have a primer bulb. Does it have a throttle control or govenor I'm wondering if someone replaced the carb at somepoint and got the wrong one. The prime hole is very obvious and should not be plugged
Hard to say what's been done with a mower somebody else owned. It has a throttle, governor, and a primer bulb.
those darn filter housings will warp and also where it mates to the gasket will flatten out and it wont prime .....make sure its in good shape and replace it if need be good luck
That part is NLA and with that hole plugged it's isn't going to prime anyway.
Since there seems to be some doubt here I'll post some pics. The carb # is 214570. Engine number 12f702-1814 E1 Serial# 97071659. This pic should lay to rest any doubt that the hole is plugged or was never drilled out:
This is the plastic "cam" on top of the choke shaft:
Is there a circuit in there somewhere where the green line is?
Heres the primer bulb and filter plate
