metz12
So in the latest storm my aftermarket tiawan made starter failed. In the first big storm where it was really cold the starter gear didnt want to move up on the shaft to turn the engine, so I took the thing off, and put it inside to warm up. after I did that it worked fine. This time I tried the same thing since it was frozen again and when I took the bolts out the starter gear and the shaft had broken off the starter motor! So I ended up having to shovel my driveway. So now getting to the point is i want to try to make some kind of wood snow plow for my mtd. This way I have a backup and if I get a couple more driveways I can have one of my buddies plowing too. I need ideas of how to mount it, and the cutting edge on the bottom. I was thinking of doing something like this:
and this is the front of the tractor http://www.lawnmowerforum.com/members/metz12-albums-snow-storm-jan-2013-picture19073-007.html
