reynoldston
- May 23, 2011
- 92
- 5,705
does it heat you out of your shop or is it not as large as it looks
What you see is only my wood shop. There is a wall and door that goes into my mechanical shop. Yes it gets too hot if I just heat the wood shop so then I open the door and heat the two shops which works out OK. Both my shops are insulated and I can just work in a T shirt all winter long. Also in my mechanic shop I have a large wooden overhead door that I lost a lot of heat out of because it isn't very weather tight. I also buy my fire wood and heat my house with it also, so I have to be careful with it. I go through about 10 to 12 face cord a year.
