Please Check The Condition Of Your Mower Blades On Your Mower
davbell22602
  • / Please Check The Condition Of Your Mower Blades On Your Mower
Pulled these off a rider this past summer that I had to replace before selling because I couldnt sharpen the blades.
Carscw
That's getting your money's worth out of them.
I see about 2 dozen every summer that look like that. Dang MTD blades. Years ago you used blades until you couldn't sharpen them anymore. Now it seems like blades don't even last for a mowing season.
metz12
i got my mtd like that! i also got it cheaper then he wanted because the blades we bad like that. when i tried the thing out i put the blades on and mowed a strip of his grass and there was like a 2" strip of grass not cut i told the guy"it doesnt cut in the middle, i'll give you 75 bucks" came back at me for 100 and i said deal. he came down from 350! so the junk mtd blades that wear down like that can save you a couple hundred bucks!
066
yep same in this part of the world, people just don't like spending money, or they just have no idea of what is going on.
reynoldston
As I recall the last set of MTD blades I bought I can understand why they ran them like that. I don't remember what I paid for them but as I recall they were pricey.
I sharpen mine every week, and clean the deck out while I have it jacked up. If you leave them dull that is what it does to them over time.
davbell22602
The blades in the pic came off of a Sears 38in cut rider. One of the gray ones with no headlights.
I have seen it before with those mulching blades. Mine had them, and they are in the dumpster now they are a pita to sharpen, and get them to balance out right. I changed them out for the standard high lift blades.
