john higginbotham
My2166 stopped traveling. was a quart low, added oil, went 100 feet and jerked a couple of times and quit again. HELP???:confused2:
What type of oil did you add...
How many hours are on the tractor, how many hours are on the oil?
How many hours are on the filter?
also a quart is about 15 percent of the total capacity, so you could have air in it.
you may have better luck getting any air out of the system if you jack the drive wheels up and power them forward & reverse until everything is operating smoothly. :smile:KennyV
What is the part number for the wix filter? I thought the proper oil is a hydraulic oil?
