Rotate the flywheel so that the piston is at top dead cylinder, and both valves are fully closed{rocker arms loose}. Measure the clearances using feeler gauges and
post them here, I am betting that they are too great, thus causing your problem. That is your next step.
Thanks, and I did get the engine to finally allow me to pull over with the plug in , by tightening those valves.
I thought I had this problem fixed, but after putting it back together, I am not able to get any starting action with the engine
Also, it feels now like there maybe not enough compression. I do have spark, and I used a lot of starting fluid in the cylinder and intake. Didn't help at all.
Not sure if this is possible, but I think I may have adjusted the valves to stop the jam up, but may have not adjusted them properly and caused another problem. I'm still confused on the whole TDC and 1/4 past TDC stuff as I don't even know what I should be using for this engine. Also, the feelers I have only go down to .006. So, how I adjusted the intake (top I think) was to tighten down on the .006 feeler until it would barely move.
The only other thing I'm puzzled by is the engine oil. It seems to be overfilled and maybe filled with gas. I lost a LOT of oil on the floor when I took off the valve cover (more than they say should come out), and still the stick is showing slightly above full on the oil. I also had oil literally shoot me twice in the face when I was pulling the rip cord with the plug out (shot from the cylinder). Now, I did have the engine tipped backwards on edge a lot, so that probably causes some problems like this. Not sure what any of this means, but would appreciate any more ideas. In particular how I can make sure those valves are adjusted within the proper spec. Thanks!
