wants to die when warm
dwint
I have a 7h.p ohv briggs and it wants to die after about 8-10 min.i tried pushing the primmer button but that floods it.is this a coil problem?
Fish
I would check the valve clearances first.
dwint
do you no what they should be ?
MBDiagMan
Also in the case of such a condition with an air cooled engine, there's always the possibility of piston/cylinder siezure. When it dies is the engine easy to turn? If it is not easy to turn when warmed up, you might have a siezure issue.
Larry
EngineMan
You say there is fuel so it can't be fuel starvation, could be the valves has already posted, it is very hot in that 8-10 minutes..? if so then check for good spark the next time it die's out.
You didn't post the engine numbers so you can check yourself with the chart.
https://www.dropbox.com/s/a0fb9kprm...ecs_english_all BRIGGS & STRATTON_engines.pdf
dwint
its not getting hot.this engine is somewhat new.
sgmgarden
I'm afraid I am not quite sure what could be happening, I do hope you get it sorted.
Carscw
As soon as it shuts off pull out the spark plug and check for spark
Carscw
C'mon...find another forum for your Troll-like comments(aka get a life).
It really works. Put the coil in the oven and cook it for a couple hours.
