Ok, so I am not an engine guy, but I am learning slowly.
Mower: Murray Select 12.5HP/40"
Model: 405002X8a
Engine: Briggs and Stratton
Model: 28v707
Type: 1113-E1
Well it's kind of old, about 12-13 years maybe? Been running fine for the first month and a half or so of having it out and mowing after winter. Did all the usual things, charged batter, replaced gas (emptied before winter), and added oil and replaced blades. I go to mow last week and about 5 minutes into mowing it just locks up, sounded like when your blade hits something and stops your engine, but I didn't hit anything.
Longer story short, the flywheel was locked up and loosing up the bolt that holds the flywheel down and addig oil slowly loosened it up. So I tightened the bolt back, and now my problem is the flywheel turns way faster than usual and I don't see the carb doing anything or even a spark? I checked the magnet coils and spaced it properly, but not sure what the issue could be. It just spins like crazy and I have searched all over and can't find anyone that has had the same problem. If Any more info is needed, I will gladly oblige. Any help is appreciated, I am sure it is a lost cause, but you never know.
Model: 405002X8a
Model: 28v707
Type: 1113-E1
