Mini Motors
- May 11, 2011
- 8
- 226
If it is truly spinning because of a bad key, you don't need a puller, it's already loose. If it's not loose, the lack of resistance means much worse, like the connecting rod broken off and just out of the way enough to not hit the crank. From the looks of the video, it doesn't sound like the piston is sliding back and forth like it should.
