The HRX217HYA owner's manual says after mowing, allow the engine to cool for 1/2 hour before washing the mower, and doing so before then could damage the engine.
Having mowed with an HRX217 for several years, I know that the only way to prevent grass from drying into a glue-like mess below the deck is to thoroughly remove it with a water hose. I usually wash it within 15 minutes after mowing, when the engine is still warm, but not too hot to touch.
I try to not spray water directly on the bottom of the engine, but it's impossible to clean the deck without some of the cold water contacting the aluminum engine block. Does anyone think this could damage the engine?
Another question involves lubricating the control cables with silicone spray. The manual says to lube the cables after washing the deck, but it's not clear if this should be done every time the mower is used, or only when preparing it for storage at the end of the season.
