avoglade39
- Mar 6, 2013
- 11
Thye muffler on my GT2050 has blowen out , a hole has appeared.. all baffles broken. It has done 130 hours. Has any one had similar problems
130 hours is not enough time to 'burn' out a muffler... That is what normally happens to exhaust components. They weaken from heat and rust/erode to the point of falling apart under normal operation pressure, generally takes a long time...
If you have other problems like back fire conditions that will actually over stress the muffler... You may have sudden failures Not associated with normal operation... :smile:KennyV
