D
Deleted member 97405
Guest
Yes, with the keyswitch on, there should be power at the yellow wire at the keyswitch. The keyswitch simply connects the red wire and yellow wire (#400a) in the 'run' and 'start' positions. See the blue circled area on the diagram below. If you have power at the red wire, but not at yellow wire at the keyswitch, I would replace the switch.
