ZT1540 only runs with parking brake on.
donelwell
Started up this spring and engine and blades with only run with the parking brake on. If I take parking brake off, wheather with the blade running or not, it stalls and dies. Had no trouble with unit when last used. Any help. Thanks in advance.
Some one has been playing silly buggers with your wiring.
The seat switch is not working and neither is the seat / blades interlock.
donelwell
thankyou will try to figure out seat and blades interlock??? problem.
