Zt hd 48 will not start.
Mowed my lawn this morning. After mowing I used the blower to blow the mower off. I went to put the mower in the garage and it will not start. I hear a loud click when I turned the key. Check the 25 amp fuse it was good. Checked battery voltage it was good. I jumped the solenoid with a scew driver with the key in the run position and it started. I guess the solenoid is bad? Brand new mower with 13 hrs and already problems, not happy about that!
mechanic mark
I checked for bad connections but all seems good. I'll take a look at it again.
to check the solenoild run a + wire to the trigger which is generally a small terminal near the base.
If it has 2 small terminals then one is + and the other is -,'
Blowing you have most likely blown one of the rigger wires off, happens all the time.
