2022 model - 17RIEACL010 - has maybe 200 hours or less on it. Was mowing and it just quit. Won't start now. Replaced plugs, gas is new and fresh, made sure carb and associated parts were clean. The mower will start (with choke pulled) and run... as long as I keep the switch turned to the start mode. When I release it to run, the mower stops. Dealer is backed up, as well as local shops. What I knew about mowers... I lost after my second brain surgery in September 2022. I hope someone can help. Thanks in advance.
