bkeller500
- Jul 2, 2018
- 7
- 285
The rattle is likely metal rubbing metal or a belt that may not be tracking properly due to assembly issues. It will probably not be a serious issue but it could be the beginning of something that will become a bigger problem later. If the dealer is aware of the problem, he should be able to point to the problem so you know exactly what it is and you can decide if you are willing to live with that issue. Metal on metal will become a wear issue. Will that become a replacement part issue or a welding issue? A belt not tracking properly will never heal itself. Higher RPM's may disguise the situation but it won't fix it. If it is a known problem then what are the plans from the factory to fix it? If there are no plans to fix it, your stuck with it. Nothing worse than owning a lawn mower that you compromised with and have regrets down the road. If you are going to spend that much money you deserve a properly manufactured machine. Even with a discounted price, you have to deal with it every week that you own it. It's kind of like buying a used car and finding out later it has mechanical issues. You will beat yourself up over and over. Be patient, You may be better off to continue to use a mowing service awhile longer until you find exactly what you want.
