Mad Mackie
- Jul 11, 2011
- 1,851
Hi bobby,
I just looked at the parts manual and from it I think that you can turn the shaft by putting a socket and a breaker bar on the L/H blade nut as if you were going to remove the blades and turn it which will turn the driveshaft so you can lineup the grease fitting. You may need to remove the safety shield on the L/H pulley area to gain access to the nut. Make sure that you remove all tools before you start the engine and operate the deck.
