Z4822 not starting after uplifting experience
vangreenacres
Thanks all, for the advice and help on the hydro-locked engine. Got'er running just fine until a new problem popped up--never happened before.
Any idea what may cause a gasoline leak following this experience? I ran the mower a few nights ago with no incident (about 10 minutes to check things out.) Last night, I mowed for 90 minutes and parked it overnight only to find a small puddle of gas leaking this morning before work. Attached are photos. Not a big leak, maybe dripping once a minute. After work, I plan to clean up the engine for a closer look tonight.
Would appreciate any thoughts.
You have a bit of gunk between the needle & seat preventing it closing fully.
A quick carb clean should sort it out.
vangreenacres
Thanks a million for the suggestion. I'll give it a try after work tomorrow..
