Boudreaux In Eunice La.
Reset the governor today. Although I didn't notice any movement once I had it loose. Once I had everything tight. I let it run long enough I knew it should be pulsing. No longer pulsing. I was flabbergasted. Movement that was imperceptible to me had done the trick. I need to mow today. We'll see if it is still fixed after I'm finished.
Ed
When you reset the gov arm clockwise you tightened the spring ever so lightly. Glad you got it right ~!~!
