eldowdy
- Sep 4, 2011
- 55
Try running some seafoam in the tank first, It should clean out any buildup. It will take a couple of tanks. Cheap easy 1st try solution, All gas is crap these days.
I will give that a shot.
Ed
Ed
Is your choke separate from your throttle ?
I think you have one of the Nikki carbs on that one Single bowl type or the wide double barrel ?????
The wide one is tricky.... Oh that is not a good number. I can't bring that number in my Briggs account.
You posted 44Q900-0110 is that correct ?
Let us know Mon Ami ~!~!
There is one gasket you probably missed it is inside you have to take some screws out to get to it Did you have a gasket left over from the kit
I had no gaskets leftover. I have a photo record of the entire rebuild. The gasket that was mentioned in the Youtube video was changed. All parts were replaced in their original positions. And yes it is a Nikki carburetor. It's not running rich. It surges in fast idle when not under load. I don't have an ultrasonic bath to clean it in. From what I have been told by a very good Briggs tech, it probably wouldn't help anyway. But I appreciate your trying to help.
Ed
You have a Governor setting problem, and it will take a very high experience carburetor person to get it right. I had the same problem on my John Deere 345 years ago and I fixed the problem with a spring like the one you have on the governor-carburetor by attaching it so the governor will not move at high idle.
